pciebifurcation Bifurcation Conundrum: Seeking Mobo Advice for 3x GPU Build
30 minutes ago, Dennettic said:I can't use for my storage? What if I switch to SATA? Is there way to use the 24 "usable" lanes for just the x16 slots?
The lane usage is hard wired into the board so you can't change it manually, regardless of how many of those lanes you use for a M.2 slot.
The motherboard manufacturer would have to intentionally not use the CPU M.2 lanes to redistribute those lanes to a third graphics slot and the demand for that is just not there. I suppose there is a small chance they'd do that with Epyc 4004, but for a consumer board? I can't see the justification.
30 minutes ago, Dennettic said:Even the title from ASUS support page mentions the " of PCIE bifurcation between Hyper M.2 series Cards and Graphic Cards" (https://www.asus.com/support/faq/1037507/)? Am I not understanding that correctly?
When ASUS talk about bifurcation they mean splitting the lanes of an existing hardwired slot, NOT redistributing lanes from the CPU.
If you use a Hyper M.2 expansion card, they put multiple M.2 slots on a single card and for all of those slots to work, you need to split the lanes on the PCI-E slot.
For example, you buy a Hyper M.2 card with 4x M.2 slots. You plug this card into your primary graphics slot. You then use the BIOS (bifurcation options) to split those 16 lanes into 4/4/4/4 so that each M.2 slot will operate with 4 lanes each.
