Cooling a i7 4770 in HTPC
Solved by WoodenMarker,
10 hours ago, Molesy said:yea the nose does get loud at times. I have not tried undervolting it at this time. I think i will get the new fans and the cooler and that should be good enough fr now. the PC does sit in the tv unit so airflow is a bit restrictive. atm the temps i saw were with the case open outside the unit as i was cleaning it up.
In that case, the NH-L9x65 would help. It might be better to get a lower profile cooler to give more breathing room between the cooler and blu-ray drive. Where are you shopping / located?
It can still help to try undervolting. I'd suggest manually setting core voltage to 1.2v and testing for stability. If it seems stable, you can try slowly lowering voltage to lower temps further.
