I have a Sapphire Radeon R9 280 3GB Dual-X Boost OC working well four a  year or so . Last weekend when i started the computer i got a no signal on my screen (connected via hdmi ) . fans working fine pc seems to run but still i get no signal from my gpu..tested my gpu to another build and still same problem. cleared cmos  and even tried using another output to an older screen , yet nothing at all. Any help or ideas what should i do?
https://linustechtips.com/topic/917910-need-some-help-with-my-gpu/
What are your full specs? Also test your power supply in another system.
Welcome to the forums!
2 minutes ago, StratosChalkopiadis said:
i5 4440
8.00GB Dual-Channel DDR3
MSI H81M-P33 V2
Evga 600 80+ bronze
Already tested my psu into another system, thx tho for  helping
Try turning on your system without the GPU installed.
Also, make sure to quote or tag people when replying to them otherwise they may not see your reply. :)
System booting just fine without the gpu using intergrated .
Your GPU is either dead, or the PSU can't power it. Try powering another GPU in a different system with your PSU.
Just now, StratosChalkopiadis said:
Done. working smooth. So in case of dead gpu any way of restoring it ?
There are some ways:
If the GPU itself(as in the processor itself, not another component on the circuit board) is dead, then you're officially in the market for a new GPU.
