Use graphics card to transmit RF output.
Modern video cards don't have VGA anymore.
DAC is short for Digital to Analogue Converter , it's a section of the video card chip which takes the digital signal (a series of bits 1s and 0s for every pixel in every frame that's sent to the monitor) and converts those bits in three voltages, one for each red , green and blue part of the RGB pixel, and it repeats that for every pixel in every frame sent through the vga connector.
The voltage could be between 0v and 0.75v, for example if the red part of your pixel is at half intensity (127, because you have 8 bits per color, so 0.. 255 values per color), then the DAC produces let's say 0.38v and puts it on the vga pin that sends the RED color to the monitor and keeps that voltage for a few nanoseconds ( 1000 ms divided by number of frames let's say 85 and then divided by number of pixels let's say 1024x768 = ~786432 ... so for 1000 / 85 / 786 432 = 0.00001495 ms
Anyway the idea is that a few million times a second, the voltage on three pins on your vga connector may change depending on what's on screen, depending on color of pixels.
Like I said modern video cards (RX series from AMD and Pascal aka GT and GTX 10xx from nVidia) no longer have this analogue circuitry on them). You'll need older cards to attempt to use the video card like in that guide.
Also note that the more modern the card is the more likely the card will have additional circuitry to smooth out and filter and make the signal output on vga cleaner, so the software may not work as well as that guy managed to achieve.
