Posted April 16, 2018 They are like 10 times the price. If they have air purifier function, thats its slightly more acceptable. They are expensive, but i kind of want to get one... Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 16, 2018 (edited) I think Jake Kastrenakes of The Verge can answer that for you Too bad Linus, et.al sold their souls to the Dyson vacuum cleaner Edited April 16, 2018 by captain_to_fire There is more that meets the eye I see the soul that is inside Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 16, 2018 The blade arent visible, but there is one at the base. The only advantage I consider it to have is not cutting children's fingers. CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 16, 2018 If it's the standard bladeless fan ones, they don't purify the air. But if you're willing to spend even more money, they have an air purifying model. My only concern with them is unless they actually have filters on the intake, you're going to have to take it apart once in a while to clean it since contrary to what they say, there are blades in the fan at the base. And it looks more annoying to take apart than regular fans. I have a blog! And a list of guides I've posted Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 16, 2018 I have a Dyson fan, and love it because it's easy to clean of dust (not a huge deal admittedly, but it's something) and is quiet. I'm not convinced it's actually better than a normal fan though (or the 10 fans you can buy for the same money combined), aside from aesthetically and stopping kids poking the blades. I'd buy another, but perhaps the purifier one. Edit: Just remembered, mine does sometimes creak when oscillating, I can't work out how to get it apart to sort that out - so perhaps that's something to bare in mind! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
