Budget & Location
 US $1100-1900
2. Aim
System will be used for gaming mainly. Looking towards recent FPS and open world games (Games around quality of rainbow six siege). Not sure if I want to overclock, or if it will really be necessary. I'm trying to get a lasting system for my budget, willing to land in that 1500-1700 sweet spot.
3. Monitors
I'm laptop currently, I'm looking for a 22.5" to 24" monitor that has good colors and semi-bright screen. Currently, AOC - G2460PF is my choice from what I could tell was good budget.
4. Peripherals
Razer - Cynosa Chroma Wired Gaming Keyboard (If there's something that can be improved with this, lemme know.) Windows 10 Home OEM 64-bit
5. Why are you upgrading?
Going into PC gaming, wanted to start pretty soon. Noticed my current laptop is struggling to run popular games I've been doing (Fortnite, PUBG, even CSGO sucks sometimes)
6. Parts in my plan as of posting
https://pcpartpicker.com/user/Bwopper/saved/p4fWXL
The GPU, being my most expensive component, has made me very stressed. Idk which GPU to begin with. As I'm new to pc gaming, I'm not sure what I particularly need, considering I'll be getting the games, not having them already. My GPU as of my current plan in my opinion may be overkill
The CPU is what I'm also thinking about. I'm currently thinking of getting a Ryzen 7 2700/2700X or Ryzen 2600/2600X. If I should use these for overclocking, I'm not sure.
The motherboard was also annoying. I'm very lost in which to choose. The X370 seemed like a quality, budget choice. I'm sure there are better ones out there.
The case: Oh dear god please help me. Do I get one with pre-installed coolers or buy coolers separately? Which cases are more organized and easy for installing your parts?
PSU: Very limited knowledge on what is the better part. All of them seem so familiar.
Storage and Memory: I don't know how they are better than the others.
https://linustechtips.com/topic/916984-first-build-1100-1900/
9 minutes ago, Bwopper said:
Wait for Ryzen 2 on the 19th
don't buy MSI AM4 boards
You don't need a GTX 1080 for that display, go for like a GTX 1050ti while prices are still insane it will be mostly fine
You don't need to buy windows you can get it for free from microsoft using their media creation tool
I can't tell where your $2000 budget went though...
there are cheaper RGB membrane keyboards
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245496
19 minutes ago, Bwopper said:
Budget & Location
 US $1100-1900
2. Aim
3. Monitors
4. Peripherals
SOMETHING LIKE THIS SHOULD BE BETTER. ..I HV EVEN ADDER ALL TGE PERIPHERALS. .
CPU: AMD - Ryzen 7 1700 3GHz 8-Core Processor  ($254.98 @ Amazon)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($123.88 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($165.99 @ Newegg Business)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  ($60.99 @ Best Buy)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB WINDFORCE OC 8G Video Card  ($579.99 @ Newegg)
Case: Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.89 @ OutletPC)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit  ($35.00)
Monitor: AOC - G2460PF 24.0" 1920x1080 144Hz Monitor  ($184.13 @ Amazon)
Keyboard: Corsair - STRAFE Wired Gaming Keyboard  ($80.90 @ OutletPC)
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse  ($45.99 @ Amazon)
Headphones: Logitech - G430 7.1 Channel  Headset  ($37.99 @ Amazon)
Total: $1779.51
Generated by PCPartPicker 2018-04-15 23:10 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245518
22 minutes ago, Bwopper said:
Budget & Location
 US $1100-1900
2. Aim
3. Monitors
4. Peripherals
#UPDATE ...
THIS SHOULD BE EVEN BETTER...
8700K + 1080TI
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($346.89 @ OutletPC)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($99.99 @ Newegg)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard  ($147.18 @ OutletPC)
Video Card: Zotac - GeForce GTX 1080 Ti 11GB AMP Edition Video Card  ($859.00 @ B&H)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($81.99 @ SuperBiiz)
Monitor: Acer - GN246HL 24.0" 1920x1080 144Hz Monitor  ($189.99 @ B&H)
Total: $2071.80
Generated by PCPartPicker 2018-04-15 23:14 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245526
1 minute ago, vexicus365 said:
Wholly unnecessary for a 1080p 144hz display lol
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245530
Ryzen 2 is pre-order soon
that gpu will push more than the monitor you've listed, go for either 1440p 144hz or 1070 or less
think about a 10 keyless keyboard, I find that when gaming I want my left and right hand closer together so I don't bump the keyboard with the mouse, but this is purely subjective.  I would consider ditching rgb and putting the money towards a mechanical keyboard, but you seriously need to feel the different switches.  I have the razer black widow TE with greens and absolutely love it, to the point that I broke my two rgb sets (razer and corsair keyboard mouse and pad) in two and have a mish mash for best feel rather than rgb echo system.
gpu's are getting to be in stock again, if you wait a bit it might get better and who knows what will happen with new launches.  Maybe look into an amd gpu if you're going 1080p 144hz (freesync is easy to get)
research the exact psu, EVGA is a strong psu company but here in the forums I hear that not every model from reputable manufacturers are perfect.
Audio go Brrrrrr
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245531
I use my Titan Xp fr 2 1080p 240hz benq zowie monitors....
He can add more monitors later on
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245540
Then what should I buy? What should I look for?
All these 1050 Ti's are from different manufacturers, and I'm not sure which one to buy
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245542
Thanks for the recommendations on the GPU. It was definitely the trickiest part of the build. I can try and see what my prices lower down to from rgb.
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245548
I would take the gpu money and put it into peripherals, sacrilege I know but having the right peripherals makes all the difference.  I have 3 mechanical keyboards and 3 gaming mice with 2 rgb mouse pads.  I have selected what I like best and get frustrated trying to use anything else.  FYI I'm using Razer Blackwidow Chroma Tournament Edition greens, Corsair MX65pro rgb, and a cloth mousepad.
That or bump up the display to 1440p 144hz and keep the gpu
Audio go Brrrrrr
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245568
I need some help finding a monitor, and a new gpu, its all very hard for me to choose. I don't know which manufacturer is more reliable, and if i'm getting the best value for my build.
Edit: Dell - S2417DG 23.8 could be a good choice for me
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245595
I'm more into performance per dollar stuff
This PC is going to be fine at the price point, could maybe just use a better CPU cooler
Could also wait for Ryzen 2 in like 4 days
Saves you $1000 for whatever down the road, probably a next generation GPU and monitor upgrade at the same time. Also lets you know if you even care about 144hz. I prefer 4k 60hz over 1080p 144hz and I play esports titles even.
PCPartPicker part list: https://pcpartpicker.com/list/LsJGcY
Price breakdown by merchant: https://pcpartpicker.com/list/LsJGcY/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($174.98 @ Amazon)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($74.39 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($164.99 @ Newegg Business)
Storage: Western Digital - Blue 250GB M.2-2280 Solid State Drive  ($73.95 @ Amazon)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB ACX 2.0 Video Card  ($204.98 @ Newegg)
Case: Cooler Master - MasterBox 5 (Black) ATX Mid Tower Case  ($54.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Gold 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($75.45 @ Amazon)
Total: $1067.65
Generated by PCPartPicker 2018-04-15 23:44 EDT-0400
Or there's a GTX 1080 with a 1440p 144hz IPS display, up to you if it's worth it.
PCPartPicker part list: https://pcpartpicker.com/list/QM8CLJ
Price breakdown by merchant: https://pcpartpicker.com/list/QM8CLJ/by_merchant/
Monitor: Nixeus - NX-EDG27S 27.0" 2560x1440 144Hz Monitor  ($429.99 @ Amazon)
Total: $1688.52
Generated by PCPartPicker 2018-04-15 23:47 EDT-0400
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245610
6 minutes ago, Bwopper said:
Dell - S2417DG
I'd go for IPS over G-sync in the Pixio or Nixeus free-sync display above, both use the same panel I think.
There's also the ultrawides if you're feeling crazy.
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245614
4 minutes ago, Bwopper said:
I'm definitely planning to purchase a Ryzen 7 2700, not sure if 2700x is the best investment though
Might as well get the R7 2700X if it's only $30 more, Probably not too huge a difference though
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245630
Total: $1067.65
Total: $1688.52
Noticed that motherboard's reviews, AB350M Pro4 Micro ATX, were pretty iffy. Any other options? I'm willing to go up a bit on motherboards if it means more quality
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245642
Wow, thanks Street! This information should help me cut back on costs. I also definitely knew my gpu was somehow overkill. I hope this build comes out fresh
A GTX 1050ti is slower than a 1080 or 1080ti of course.
but like 1080p low settings you're still getting 100fps, I use an RX 560 on a 4k display, not running AAA games at native of course.
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245644
I use an overclocked R7 1700 on that motherboard's VRM, and the RAM at 2933mhz it's fine. *I have a fan over the VRM because it does get hot at 1.375V
But better X470 motherboards are coming with Ryzen 2, and if you're buying an R7 2700X you might want a better board, like the upcoming Gigabyte board with real VRM heatsinks.
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11245649
The AOC G2460PF is a no-go. I have both the g2460 and the S2417DG, and the colors on the AOC one is just ugly no matter how hard I calibrate it, not to mention it's Freesync, which means you won't get anything out of the  The S2417DG is much nicer, but you will have to download a custom color profile to make it look nice. It's probably the best value 1440p gsync monitor out there and I love it a lot (with your budget you should just go 1440p anyway).
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11246275
don't bother with ryzen 7, games don't use that many cores right now. wait for reviews on the 2600 and see if it performs better than the coffeelake i5/7s before choosing either. a pro4 or prime plus is enough for a ryzen 1600/2600.
the stock cooler should be enough unless you plan to overclock it high, take a look at the Define/meshify C, P400/S TG and corsair 275R.
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11246297
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  ($237.59 @ SuperBiiz)
CPU Cooler: Scythe - SCNJ-4000 84.6 CFM CPU Cooler  ($39.99 @ Amazon)
Motherboard: MSI - Z370 SLI PLUS ATX LGA1151 Motherboard  ($133.00 @ B&H)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($74.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB G1 Gaming Video Card  ($619.99 @ Newegg Business)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Gold 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($74.99 @ Newegg)
Monitor: Dell - S2417DG 23.8" 2560x1440 165Hz Monitor  ($369.97 @ Amazon)
Keyboard: ROCCAT - Ryos MK Glow Wired Gaming Keyboard  ($56.11 @ Newegg)
Total: $1881.30
Generated by PCPartPicker 2018-04-16 07:24 EDT-0400
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11246310
Thanks for choosing Seagate. We are around if any questions pop up for your drive.
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11247179
Did some editing towards the computer. I decided to use the Dell monitor.
Decided to use 1700 since I'm entry level
Added mouse and compromised with keyboards
Added the motherboard, unsure if I want to go any higher for my current setup
Changed case, will need feedback
Cooler, because I'm unsure of how the 1700 will react to recent games
Switched out the 2tb for Seagate - FireCuda 1TB 3.5" 7200RPM Hybrid Internal Hard Drive
Gigabyte - GeForce GTX 1080 8GB WINDFORCE OC 8G Video Card still has my interest.
I wouldn't like to go over 2000, but I'm open to consideration (if reasonable)
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11247944
get a prime plus or pro4/K4 instead of that mobo, and the ninja 4/SCNJ-4000 over the mugen 5. the 1700 won't perform any better than the ryzen 1600 in games so avoid it unless you're gonna be streaming.
https://linustechtips.com/topic/916984-first-build-1100-1900/#findComment-11248716
