Hello!
So i'm wanting to buy a new gpu, but I dont nkow what site/dimestions my case has, but I want my gpu to fit in my case.
I have no idea what case this even is because i bought it prebuild.
If you have any tips on about how to find out what case if have, it whould be really helpful.
https://linustechtips.com/topic/916817-what-case-do-i-have/
You could get the measuring tape and see what fits?
Most prebuilts I have see do not list dimensions for supported GPus as the manufacturers want you to buy a new device instead of upgrading your existing one
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/916817-what-case-do-i-have/#findComment-11244030
-Moved to Cases and Power Supplies-
https://linustechtips.com/topic/916817-what-case-do-i-have/#findComment-11244063
