RGB lights!
Get some strips off amazon/aliexpress for like $20 and tape them everywhere
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/915643-setup-help/#findComment-11233357
4 minutes ago, Jihakuz said:
You have this nice set up that you have obviously spend a bit of money on. And then you only have one monitor xDso maybe get some more, or an ultrawide if you want to keep one.
my bad this is a older picture I actually have 2 setup is the same just imagine one other 24 inch monitor!
https://linustechtips.com/topic/915643-setup-help/#findComment-11233367
5 minutes ago, JDE said:
RGB lights!
Im sorry I put a older picture ill put the new one on later the setup if almost the same just with 2 monitors and a new mic stand!
https://linustechtips.com/topic/915643-setup-help/#findComment-11233375
Alright, I was a bit confused, I don't think I could live without my second monitor!
important figure in mensa
https://linustechtips.com/topic/915643-setup-help/#findComment-11233376
agreed I do streaming and got affiliated by twitch I really needed one lol so I now have 2 24 inch monitor(not the same one witch is really annoying)
https://linustechtips.com/topic/915643-setup-help/#findComment-11233379
If you're happy with the gaming performance, care a lot about audio and have a lot of money to spend, I'd upgrade the audio solutions. Get a nicer sound card, like the newer Apogee Duets that work with W10/OSX/iOS and a set of new speakers. Also a new desk that's not in a corner. But hey, only if you really really care about audio, haha.
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
https://linustechtips.com/topic/915643-setup-help/#findComment-11233391
well this xmas I focused audio I have 2 polk audio speakers(t15) and a polk audio 10(psw108) inch sub and a Yamaha receiver(idk) below my desk with a Scarlett 2i4 and a mxl 990 microphone(I'm 15 a lot of this stuff is donated from electronic stores and stuff that aren't using it)
https://linustechtips.com/topic/915643-setup-help/#findComment-11233399
That sub is actually not bad. I'm sure this setup is more than fine for what you do. If you want better stereo imaging, set the speakers up so that they form an equilateral triangle with your head, with each tweeter pointed at your corresponding ear. If you use headphones a lot, it doesn't really matter that much, haha
Otherwise, as far as i can see, the best visual upgrade you can get is a new motherboard, haha.
https://linustechtips.com/topic/915643-setup-help/#findComment-11233430
im on a lga 1155 motherboard lol there arent 2 many good looking ones around that still work i have a i7 2600 because it dosent fine for what i do. but yes i will take your advice for the speakers
https://linustechtips.com/topic/915643-setup-help/#findComment-11233435
