hello, does anyone know of a good cheep cpu waterblock as I may be buying a few of them in the future im looking between £10 and £30
~james
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/91511-cpu-block/
thanks I only need them for a possible idea of mine for watercooled rack mounted servers
}else{
https://linustechtips.com/topic/91511-cpu-block/#findComment-1234830
~james
XSPC RASA. a lot of upgrading will make these surface pretty inexpensively.
fits Intel sockets 775, 1150,1155,1156,13656, and 2011.
https://linustechtips.com/topic/91511-cpu-block/#findComment-1234916
as im saying its for a custom built servers ill build in a rack so I want em decent
}else{
https://linustechtips.com/topic/91511-cpu-block/#findComment-1234944
Are you seriously watercooling a server rack? That's new.
Anyway, go for a branded block that isn't too old like the aforementioned EK Supreme LTX or Koolance 360/370.
https://linustechtips.com/topic/91511-cpu-block/#findComment-1235856
thanks the thing is a servers have dual cpu with a uncommon socket so the only way around this is to custom build all the servers. with a common socket so I can get the waterblocks on there. the reason I am watercooling as I cant have a lot of noise in the house so ill build my own giant resovoir and I will have a water chiller for pc watercooling to cooling the water.
}else{
https://linustechtips.com/topic/91511-cpu-block/#findComment-1237475
}else{
https://linustechtips.com/topic/91511-cpu-block/#findComment-1237510
The raystorm from XSPC is  a pretty good heatsink. I don´t see anything wrong with it. And usually if it fits socket 1155 it will fit socket 1150 as well.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/91511-cpu-block/#findComment-1237793
