Cryorig CR-H7A with i7 8700k and other questions.
Solved by STRMfrmXMN,
11 minutes ago, Keelan said:So what would you do?
Buy the non k version and stick to normal clock speeds?
Or buy the k version, also upgrade my case and get a AIO?
I'm just thinking for cost too.
Also do you think I would notice much of a difference between the overclock and the none overclock?
I mean the upgrade from the i5 3570k to the i7 8700k will show great results anyways right?
Get a non-K, use the H7, get a much cheaper motherboard.
