So I am making an open air case for my Dell Optiplex 780 DT and I am ordering a power supply that is ATX and its 450w 29A on the +12v rail. This would power my 560 ti but I would need a 6 pin splitter and I would be a little under the specified wattage because its a splitter and not a whole other cable. Should I use my Corsair CX500 in that and use the 450w in my main rig which doesn't need a 6 pin. (My CX500 has 2 6 pins) I am planning on upgrading my main power supply soon so it would only be for a little.
https://linustechtips.com/topic/913928-power-supply-swapping/
if it doesnt have 2 6pin, it's most likely a bad or ancient PSU. You shouldnt buy it
Desktop benching:
https://linustechtips.com/topic/913928-power-supply-swapping/#findComment-11217364
2 minutes ago, WolfireSounds said:
It's a BFG Tech LS-450 (80+ Certified)
Exactly. There's a PSU tier list in the Power Supply subforums and I urge you to check it out. Tier 3 or above units are good, tier 4 for decade old systems you dont mind losing. Stay away from the rest.
Desktop benching:
https://linustechtips.com/topic/913928-power-supply-swapping/#findComment-11219259
