then dont overclock
Desktop benching:
https://linustechtips.com/topic/913593-extremely-low-fps/#findComment-11213736
Did you switch to PCiE for graphics in your BIOS settings?
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
https://linustechtips.com/topic/913593-extremely-low-fps/#findComment-11213748
DDU in safe mode and reinstall the drivers fresh new, also delete whatever program you used to overclock the GPU.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/913593-extremely-low-fps/#findComment-11213773
34 minutes ago, Cosmin17 said:
So, I overclocked my 1050 ti and for no reason my cpu is not being used anymore (by that I mean low cpu usage in any games ~20%) And ofcourse this cause very low framerates, ~10-20 fps . Please help me out ! ??
CPU: i3 7100
GPU: 1050 TI 4GB
RAM: 8 GB
You had this issue before the overclock? What game are you trying to play? Got any advanced settings on that will fuck you gpu up like SMAA or upscaling?
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/913593-extremely-low-fps/#findComment-11213811
Ok... the CPU not being pegged at 100% is a GOOD thing as long as your GPU usage is >95%
the next thing to figure out is your GPU performance. For that will need:
1- full specs including the OC
2- thermal data
3- performance metrics such as FPS/CPU/GPU thermals and performance
4- the game/software with issues including settings. Look for anything that says “scaling”
AMD Ryzen 3950x under a Noctua D15S, 32 Gb G Skill FlareX 3200 DDR4 running at 3200 CL14, Gigabyte Aorus Pro 570 Wifi, Gigabyte 2070 Super hooked to a Dell U2718Q 4k HDR monitor & an Acer 1440p 144hz IPS panel of some kind, an Inland 1 TB M.2 PCIE 4 main drive, a Samsung NVME M.2 250Gb, WD Blue 500Gb  and 1 TB SSDs, Corsair RMX750, Rainbows and butterflies...
https://linustechtips.com/topic/913593-extremely-low-fps/#findComment-11213824
Turns out the problem was due to the fact that I was running win 7 on a Kaby Lake cpu . Intel said that kaby lake is not compatible with win 7 but I still got it working for some time.
Thank you all for your advice! I never thought it wiould be all windows related. Anyway, everything is good now. Once again, thank you!
https://linustechtips.com/topic/913593-extremely-low-fps/#findComment-11214006
