Ive had my pc for about a year now and noticed I've been running my ram at 2133 instead of the 3200 it can go (Corsair Vengeance) and when I went to bios and changed the memory speed thing (I didn't voltage or anything) the computer would get a blue screen w the ":(" on display and when I put it back to 2133 w one stick it works again. (I can put the second stick in after at 2133 and it works fine)
Specs:
Mobo: gigabyte gaming Rev 1
Cpu: ryzen 1600 (Oc to 3.7ghz)
Ram: 16gb Corsair Vengeance ddr4
Storage: ssd boot drive and hdd storage
Gpu: MSI gtx 1050ti
Psu: 600w bronze (Corsair I think)
https://linustechtips.com/topic/913542-help-ram-problems/
Have you updated the BIOS?
Newer versions are a LOT better in memory overclocking, the very first versions were well, basically garbage.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/913542-help-ram-problems/#findComment-11213270
Specs:
Gpu: MSI gtx 1050ti
The solution seems obvious, if it bluescreens on higher settings, put it back to default.
Problem solved.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/913542-help-ram-problems/#findComment-11213289
