1 minute ago, Akshat Sharma said:
How is it that until last year AMD's cpus were not even considered as an option and then suddenly they announced and released ryzen. What change in AMD's team took place that lead to AMD rising again in the cpu market with the ryzen line-up?
The OLD FX chips were horribly old with bad IPC compared to offerings from Intel. WIth Ryzen, they made up a HUGE chunk in that gap to be competitive again with Intel. They still lag behind a little on the IPC, but they are leaps and bounds ahead of their other offerings.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/912779-amds-ryzen-cpu/#findComment-11205783
Before Ryzen, AMD made the FX line-up, which was introduced in 2011 and not really improved upon until last year because the design behind it was vastly inferior to what Intel was doing. While they were pretty good in multithreaded workloads, by the time Intel's Haswell came out, that lead was gone as well. Single threaded performance was historically poor, so they were not suitable for gaming beyond 2013 at all, as they would start to become bottlenecks to the R9 280X/GTX770 and higher cards.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/912779-amds-ryzen-cpu/#findComment-11205808
invested billions of dollars in research and development, an endeavour that took them over 4 years to end up with a CPU that is almost as good as intel's last generation CPU.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/912779-amds-ryzen-cpu/#findComment-11205812
