Intel stock cooler help
Solved by Crunchy Dragon,
The Intel stock cooler will get the job done, although I personally would recommend a Hyper 212 over the stock cooler. You will be able to remove the stock cooler in the future should you wish to replace it with an aftermarket model.
-Moved to Air Cooling-
PopsicleHustler ·
Posted in Audio2 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory10 -
11
play_circle_filled
Latest From ShortCircuit:
