Which case
4 members have voted
  1. 1. Which case is better?
    • Phanteks P400S TG
    • NZXT H700i
    • Others (Please comment with what other cases)
What components are you putting in a case and what features do you care most about?
Where are you shopping/located?
The H700i is larger and heavier if that matters. It's 12.27kg compared to the deceptively light P400S TG at 7kg due to the thinner metal.
https://linustechtips.com/topic/911721-help-me-choose/#findComment-11196169
It is going to be a Z370 mobo with GTX 1080 GPU
I am located in Canada and I plan to shop anywhere in Canada for the parts.
These 2 cases look so good.
I plan to put RGB lighting inside too and it is the reason why I am looking at cases that offers TG cases
https://linustechtips.com/topic/911721-help-me-choose/#findComment-11196419
The NZXT lighting is proprietary; It will only work with NZXT CAM software and NZXT parts (like the kraken X62)
The same goes for Corsair cases like the 460X
Cases like the P400, Enthoo Pro M SE and CoolerMaster H500P Mesh use 4 pi connectors that can be controlled by different RGB ecosystems like Asus Aura
You could also just buy a case that doesn't have RGB but has everything else you want and add it.
https://linustechtips.com/topic/911721-help-me-choose/#findComment-11198097
