The Titan MKI Project is the start of an over the top PC for a mix of work loads (For my older sibling who needs some serious PC firepower to run numbers) and a powerful gaming rig. The beginning of the project has begun with the ordering of the Case, PSU, Radiators and Case Fans. I should be ordering the rest of my water cooling components from Singularity Computer(Res,Pumps and coolants) and EK Water Blocks(GPU and CPU/MOBO BLOCK) in a week or two. I am working a full time job so i may not be as active as i would like to be but stay tuned as i plan to have this build done by June or July.
The colour theme of the build is a main black case with deep red RGB made to look like the beating heart of the PC and the hardline to look like the blood lines of the pc
Main components:
https://au.pcpartpicker.com/list/
PSU: EVGA SuperNova T2 1600w (ordered)
CPU: I7-7820x
Ram: 32gb of Trident Z RGB 3200mHz
GPU: Strix 1080ti OC (stopgap measure until 2080s in SLI)
Pump/Res: 2 Protium Large with D5 pump attachments
Storage: 1TB Samsung 960 EVO M.2 NVMe, 2x Seagate Firecuda 2TB Hybrid drive
Mobo: Asus Rampage VI Extreme
Case: Caselabs Magnum SMA8 A black (ordered)
Rads: EKWB 560mm, 480mm, 280mm and 360mm (ordered)
Fans: EK Vardar 120mm/140mm (ordered)
Tubing: 12mm OD PETG Hardline tubing
https://linustechtips.com/topic/910365-titan-mki-project/
well thats about 10 generations away :P 1100 series up next:
Builds:
https://linustechtips.com/topic/910365-titan-mki-project/#findComment-11182707
I'm a bit confused, it's a complete OTT system, but it only has an 7820x, is there a reason why you got that specific CPU?
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/910365-titan-mki-project/#findComment-11182732
The reason it has a 7820x is because it has similar gaming performance to the I9 series but is 300aud cheaper but im going back and forth between the two.
https://linustechtips.com/topic/910365-titan-mki-project/#findComment-11182768
