So I took part of my loop apart today to install new fittings and it appears my threads on my pump outlet chipped and is now leaking. Any way I could fix this or will I need to buy a new pump/res? Attached is a picture showing the chip and where it is leaking from.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/910151-need-a-possible-fix/
As Seen on TV Flex Seal Rubber Sealant, Black, 16 oz can
This is all I can really think of.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/910151-need-a-possible-fix/#findComment-11180452
you could always just buy a new pump top to save money. if the pump is okay that is.
https://linustechtips.com/topic/910151-need-a-possible-fix/#findComment-11180497
Sigh..guess I'm just gonna a buy a whole new unit. Wanted something a little bigger anyways. Gonna get an ek-res 140 Revo d5 which should fit easily in my case and mount on my ek 120 uni bracket.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/910151-need-a-possible-fix/#findComment-11180559
Little thread tape or paste worked just fine for me when that happened to my cpu block.
https://linustechtips.com/topic/910151-need-a-possible-fix/#findComment-11181888
I already bought me a new pump/res and its on its way. Got the EK Xres 140 Revo D5 edition. Its a bigger, better, and quieter pump than my Xres DDC pump I had. Yes, it cost me 170$, but worth it in the long run imo.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/910151-need-a-possible-fix/#findComment-11183009
