Certbot wildcard help needed
Go to solution Solved by Granular,
As I understand it, Let's Encrypt will only give you a wildcard certificate if you can complete the DNS challenge.
And the error for the DNS challenge says that it tried looking up the TXT record it wanted you to add in the DNS and received the NXDOMAIN response, meaning the authoritative DNS server told them that the record they're looking for doesn't exist.
Hello,
I tried to do a wildcard with certbot but this is the output:
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA. You may need to use an authenticator plugin that can do challenges over DNS.
My command
sudo certbot -d *.example.com certonly --server https://acme-v02.api.letsencrypt.org/directory --pre-hook "systemctl stop stop" --post-hook "systemctl start nginx" --manual --preferred-challenges http
and before that I tried the DNS part
sudo certbot -d *.example.com certonly --server https://acme-v02.api.letsencrypt.org/directory --pre-hook "systemctl stop nginx" --post-hook "systemctl start nginx" --manual --preferred-challenges dns
Added the txt token to the DNS  and this happened:
Failed authorization procedure. example.com (dns-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.example.com
IMPORTANT NOTES:
 - The following errors were reported by the server:
   Domain: example.com
   Type:   connection
   Detail: DNS problem: NXDOMAIN looking up TXT for
   To fix these errors, please make sure that your domain name was
   entered correctly and the DNS A/AAAA record(s) for that domain
   contain(s) the right IP address. Additionally, please check that
   your computer has a publicly routable IP address and that no
   firewalls are preventing the server from communicating with the
   client. If you're using the webroot plugin, you should also verify
   that you are serving files from the webroot path you provided.
Could someone help me on this?
Back-end developer, electronics "hacker"
https://linustechtips.com/topic/909478-certbot-wildcard-help-needed/
Oh
3 minutes ago, Granular said:
Did you add the record when you ran certbot? What DNS are you using?
I did, I use namecheap.
I'm now getting a error that the token found is wrong (which is correct as thats the last token I used) I'm currently waiting the 1 minute ttl time before I press continue.
EDIT:
And that worked :P Thanks for putting me on the right track!
