Sorry for another "loop not filling" thread, but I am very stumped and could use your helpful advice.
Here is an image of the loop
Swiftech MCP655 PWM is attached directly underneath reservoir.
Loop order is Res/pump > GPU > 280mm rad (top) > CPU > 360mm rad (side) > Res/pump
Thank you!
https://linustechtips.com/topic/909141-water-loop-not-filling/
18 minutes ago, Airdragonz said:
Fill the res until its full. Turn on the pump. Turn it off right before the res is empty. You DO NOT want your pumps to dry out. Repeat until your loop is full.
this
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11170804
3 minutes ago, skillednewbie said:
Thank you for the suggestion.
I've topped off the reservoir. No change in water level.
If the water level doesn't change anymore just moments after turning the pump on, it should be full
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11170816
Even if water hasn't filled tube from 360mm rad to res/pump and 280mm rad to CPU?
(Water levels still accurate that you might be able to see in image in original post)
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11170837
Looks to me like pump has had it, unless you didn't power cycle for the pump to work?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11170842
Then you have trapped air, need to tilt the case with the pump turned off. The pump not being the highest component in the loop affects this many times more than the loop path/order
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11170845
Just purchased pump Friday. First time turning on pump with res filled, the flow was very slow. Waited until about half full, turned it off. Filled it back up, turned it back on, and not much change after that. Maybe I need to get a replacement?
Attempted tilting case in many directions with pump off, water level did go down by about 1/4 inch. Not much has changed since then.
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11170860
Need to fix the tubes for the gpu block. That isn’t going to work. Unless the picture is that bad and I can’t tell.
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11171071
Could you elaborate? Are the tubing from the GPU to top radiator bad? From the res to the GPU? Is it a bad bend? Do I need to adjust the height of the pump/res lower to lower the pitch of the tubing to the GPU?
Thanks for your feedback. Sorry for the picture quality, I tried to get as much lighting as I could that could be helpful for you all.
I've put in an order for a different pump to possibly replace the one I have now to see if this will fix the issue. I will have an update by Monday.
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11171097
Oh crap, there's a picture. Yeah...you need to use offset ports on the gpu block for it to actually flow through the fins. Still need to get that air out though.
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11171126
Appreciate your specifying that. I'll bend another tube and see if that helps.
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11171191
AFAIK that was just another issue of your loop, it has no bearing on your stated problem. The fluid is clear, right? If you fill the res, do you see the coolant enter any tube? Or is it just staying inside the res without going anywhere?
CPU: i7 6950X  |  Motherboard: Asus Rampage V ed. 10  |  RAM: 32 GB Corsair Dominator Platinum Special Edition 3200 MHz (CL14)  |  GPUs: 2x Asus GTX 1080ti SLI
Storage: Samsung 960 EVO 1 TB M.2 NVME  |  PSU: In Win SIV 1065W
Cooling: Custom LC 2 x 360mm EK Radiators | EK D5 Pump | EK 250 Reservoir | EK RVE10 Monoblock | EK GPU Blocks & Backplates | Alphacool Fittings & Connectors | Alphacool Glass Tubing
Case: In Win Tou 2.0  |  Display: Alienware AW3418DW  |  Sound: Woo Audio WA8 Eclipse + Focal Utopia Headphones
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11171248
Is you're Pump Dead? I bought some 30$ 500L/H pump from China because it seemed like the ACR pump in the ek kit slowed down alittle bit.  And figured Id need a backup. The China Pump is a little Noisey but I do think it's performing slightly better and it holds like a 100ml more water...Gives the ACR a run for the money.
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11171275
Good eye, good eye.
@JR88
Look at how the tubing for the GPU is hooked up.
There only ONE of the ports are used; there's no in AND an out.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11171363
Ok, since you noticed the fact that the GPU block is done is wrong, did you power the whole system up? Some PWM systems require a PWM signal otherwise they only work at like 30% power, which on a pump won't work at all. Without a PWM signal my D5 barely pumps any water at all. If you're using a jumper to power the PSU to keep the system unpowered for leak reasons, you'll either need to just power the 24 pin for the PWM to work, or get another PC and use the PWM signal from that.
Yours faithfully
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11171597
A pwm pump with out any signal should run 100%
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11172267
No, not all of them do. Evidently mine doesn't. It's easier to see on fans, most will spin at 100%, but some don't, depends on how the PCB controller on the fan implemented the PWM control.
Yours faithfully
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11172599
Thank you!
Trapped air. It happens... I have even resorted to putting a tube in the top of the res and blowing to get the pump primed. Also if that is hard tubing which it looked like. . Then in am jelous of thoes bends
https://linustechtips.com/topic/909141-water-loop-not-filling/#findComment-11175920
