14 minutes ago, Technicolors said:
what should i do with the drive afterwards?
Destroy it I suppose to protect your data, or take it apart and keep the platters for coaster and extract the powerful magnets to use for other things.
https://linustechtips.com/topic/906889-hard-drive-caution/#findComment-11148512
2 hours ago, Electronics Wizardy said:
Yea penting sectors means you have data loss and errors. You should replace this drive now.
I have a drive with a similar thing marked for "Caution" running for the past two years now.
So, I would buy a new drive, but keep the older one around for nonessential data until it dies.
My eyes see the past…
My camera lens sees the present…
https://linustechtips.com/topic/906889-hard-drive-caution/#findComment-11148847
