So I thought it was high time a get my first actual build, not some spare parts I got from friends, so here it is but first the build plan:
Budget and Location:
Budget is pretty tight but around R12000.00 - R15000.00 (R=Rand South African Currency) or 1313.16 Canadian Dollar or 1641.45 Canadian Dollar
I am living in South Africa.
The site I will be using is https://www.evetech.co.za and https://www.rebeltech.co.za our local PC dealers.
Aim:
Simple, gaming like League of Legends, ESO, Diablo 3, Assassins Creed etc.
Will also be recording with OBS but LOL only maybe some Diablo 3.
Monitors:
1.....Maybe 2....
Periperals:
Mouse: Corsair SCIMITAR PRO RGB Optical MOBA/MMO Gaming Mouse
Keyboard: Corsair K65 LUX RGB Compact Mechanical Gaming Keyboard — CHERRY® MX RGB Red
Headset: Corsair VOID PRO RGB USB Premium Gaming Headset with Dolby® Headphone 7.1
Mousepad: N/A
Why am I upgrading:
Will post my current rig then you'll see why.....
 So now to the actual PC Parts:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler
Motherboard: MSI - B350M MORTAR Micro ATX AM4 Motherboard
RAM: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory
Storage: Corsair - Force LE 240GB 2.5" Solid State Drive
GPU: MSI - GeForce GTX 1050 Ti 4GB GAMING X 4G Video Card
Case: Corsair - SPEC-ALPHA (Black/Red) ATX Mid Tower Case
PSU: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply
Monitor: AOC G2460PG 24" Gaming Monitor, G-SYNC, FHD (1920x1080), TN Panel, 144Hz, 1ms
P.S I hate dust in my PC :P
Thanks Linus and Community.
https://linustechtips.com/topic/906647-my-first-build-_/
You have chosen a bad time to start building my friend.
That said, your build idea doesn't look so bad. I'd scrap the H100i, the wraith cooler should be able to hold its own. Spend the extra money on parts that actually affect performance in a larger way.
Otherwise, if you can snatch all those parts within your budget, I say go for it! (except for GPU. maybe put cooler money towards better video card?)
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/906647-my-first-build-_/#findComment-11146488
24 minutes ago, aBrokeGamer said:
Thanks will have a look at it but it gets very hot here so I might just go a a smaller cheaper version.
Trust me, I live somewhere hot and going from budget tower cooler to 240mm AIO didn't really do a whole lot. From personal experience with the 1600, the Cryorig H7 cools better than stock and performance wasn't too far off from the AIO all things considered.
https://linustechtips.com/topic/906647-my-first-build-_/#findComment-11146534
I've used an FX-8350 and having the GTX H100vi made a huge difference, however, the FX-8350 is a processor people joke about being used to heat your house in the winter. The Ryzen 1600 is a much better processor that will not put out insane amounts of heat so a 240mm AIO is not a good option to outright buy(I had gotten mine in a great deal with a  GPU and mobo in the classifieds). Your money will be best spent on like a good $40-55 air cooler, and spend some money on getting some case fans for good airflow, and some good thermal paste. With the money saved you could invest into an ATX board or if you get an air cooler closer to $60 you could also drop the case fan idea entirely and get a 1TB HDD instead, so you have enough storage for more games or video footage (which takes tons of space).
https://linustechtips.com/topic/906647-my-first-build-_/#findComment-11146547
