1080 ti strix 2100mhz and beond
Solved by Shiftstealth,
You could probably flash another BIOS on the card, but you'd be doing that for minimal gains. Very very few cards hit above 2100Mhz. I'd say you might gain 25mhz if you flash the other BIOS. IMO not worth it. You'd need to download nvflash, and have someone backup their BIOS from another card that has a higher limit, like your Aorus. I think the factory overclocked STRIXX might have a higher power target than your card if you have the non-OC one. So that might be the most viable one if you decide you really need that extra 25mhz.
