Fast sync smoothness with higher than display framerates
rfcokilljoy
If I understand correctly, running a game at say - 200fps even on a 60hz monitor SHOULD make the game feel more responsive and smooth, as there is less time between a frame being rendered and it being displayed on screen.
But does using the Nvidia control panel setting "Fast sync" which ditches frames that wont be shown on screen, remove this extra responsiveness from running games at a higher framerate?
Does Fast sync pick a random frame to display per refresh, or the one most recently rendered?
i5 7600k @5.2ghz 1.39v i7 7700k @5.1ghz 1.39v / Strix z270h / 16gb Trident z RGB 3200mhz CL16 1.35v (2400mhz CL15 kit overclocked) / GTX 1070ti sli both with Arctic Accelero Xtreme iv coolers / EVGA 750w Gold PSU
Samsung cf791 3440x1440 100hz Quantum Dot
Haven't broken something with an OC yet... YET.
I never really noticed a difference between 200fps and 60 fps on my 60hz monitor. That's why I always have Vsync enabled.
CPU: AMD 3800X GPU: GTX 1080 Ti RAM: (16GB) 2x Corsair 8gb DDR4 3200Mhz Drives: SanDisk 240GB SSD, Samsung 500GB SSD, WD 1TB HDD
Motherboard: MSI X470 Gaming pro plus PSU: Gigabyte 650 watt Monitor(s): 27 inch AOC 1440p
Fast sync just uses the most recently fully rendered frame. When fps is below the refresh rate it has no advantages over v sync but at higher fps you get power input lag. It's not gonna improve smoothness since you're still displaying the same fps but as opposed to v sync, which will cap your fps to the monitor refresh rate, fast sync let's it go however high it wants leading to lower input lag.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
Thank you everyone!! Answer very much solved :)
