144hz monitor help
reeceraum
If im playing games at around 100-130 fps would a 144hz monitor still be worth it?
Over what?  A 60 Hz?  Yes
Also -moved to displays-
5 minutes ago, Canada EH said:
What games are you playing?
Right now, I'm playing Dark Souls and HunieCam Studio. You?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
5 minutes ago, ARikozuM said:
You?
Windows Chess
Solitaire
Tetris
Minesweeper
Super Meat Boy
GTA 3 but I am done, just gotta finish the last helicopter mission at the dam
Internet Backgammon
Kuboom
Terrorhedron
klocki
So yeah, my gpu is a bit much lol
WHAT? Internet backgammon?!
Also, yes. Your frame-rate should preferably be close the refresh of the monitor. Unless you're playing HuniePop, you should receive a tangible (...) benefit from a 144Hz monitor.
If you're shopping for a monitor, go ultrawide as well. At worst, you'll be playing at 16:9, but most games do scale well with the aspect ratio and allow much more versatility than a simple refresh increase.
Honestly, if you don't mind the cost, it's "worth it" even just for general use because moving and scrolling windows is even significantly improved.  Of course any full screen high action games like the ones you've listed above will also benefit hugely.
Would it be worth it to buy an older UW model because they usually drop off in price, lets say like 2 years old? Current ones @ 700-800EU+ are too much
