Removing Scratches From Side Window
http://www.amazon.com/gp/product/B0035U5ARK/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A1Z0LSQOD17H0Y
Has anyone here ever used this product or something similar for their plexiglass side panel window to remove scratches? I used some wipe to take off the dust and all I did was create swirls of scratches  :unsure: later realized acrylic scratches very easily. Also, a big no-no for using Windex. Oh, and my side panel window is not tinted if that matters.
Would really like to know. Thanks.
Mobo: Z97 MSI Gaming 7 / CPU: i5-4690k@4.5GHz 1.23v / GPU: EVGA GTX 1070 / RAM: 8GB DDR3 1600MHz@CL9 1.5v / PSU: Corsair CX500M / Case: NZXT 410 / Monitor: 1080p IPS Acer R240HY bidx
https://linustechtips.com/topic/90494-removing-scratches-from-side-window/
If its really badly scratched could you not just replace the side panel, assuming its easy to remove, perspex isn't that expensive?
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
Even if you manage to remove the scratches new ones will emerge after you clean the window with a cloth. The only thing, which is a permanent solution for the problem is using a glass window instead of a plexiglas one.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
That may work but it's not badly scratched. Just little scratches that swirl a bit. It sort of annoys me.
oh I see, just try that stuff then.
