Static and Whine Coming From Speakers and All Ports
I know this is a bit old, but as a guy that build amplifiers out of passion for audio, that static is almost always due to high input impedance of the device at the other end of the small signal audio cable, i.e. amplifier, mixer, etc. Nowadays, PCs have pretty good sound chips so i've resorted to using lower input impedances. My amplifiers are around 10k input impedance, tried even 1k but some devices had trouble with that (not PCs). The reason why you can use low impedances is due to them being designed to drive headphones, which are around 30 to 600 ohms. The lower the impedance, the lower the noise picked up from power lines running in the vicinity of your small signal audio cables. The dacs and opamps used have a high power supply noise rejection so it's really unlikely that dirty power is the reason for the static noise. Hope this helps you or others in distress
