HELP!!!!
so i think my graphics card isnt working properly so today i went to launch a game and it crashes and i try my whole steam library and nothing is working so i try downclocking my cards which is a gtx 1060 6gb gaming x edition and my power supply isnt the issue because it was working just fine yesterday when it was overclocked and today i downclocked it by 200 mhz and the game worked just fine. so what should i do i can send the card back and get a new one
https://linustechtips.com/topic/904800-help/
What PSU is it? What's the rest of your system?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/904800-help/#findComment-11128659
3 minutes ago, savagepain said:
https://pcpartpicker.com/list/TzhXLJ
 thats my system
What do you mean by "crashes"? Does the game just close? Does your PC lock up? Is it a BSOD?
SPECS:
https://linustechtips.com/topic/904800-help/#findComment-11128678
Just now, savagepain said:
okay so when i launch the game it will just load for a sec then crash as in the completely closes
Try reinstalling Microsoft Visual C++ or whatever the fuck it's called.
SPECS:
https://linustechtips.com/topic/904800-help/#findComment-11128694
i did
17 minutes ago, TechyBen said:
450 watt may be too low for the 1060. It can be recommended for a 550 for that card.
(Will update post in a second, searching PSU recc)
my system isnt shutting down though
https://linustechtips.com/topic/904800-help/#findComment-11128698
17 minutes ago, savagepain said:
i did
Any error codes or anything?
@savagepain Try running some stress tests.
SPECS:
https://linustechtips.com/topic/904800-help/#findComment-11128702
4 minutes ago, savagepain said:
already did furmark and adia64
And? Did they run fine at normal clocks?
SPECS:
https://linustechtips.com/topic/904800-help/#findComment-11128720
2 minutes ago, savagepain said:
yeah
Then it's an issue with the games. Try reinstall Windows.
SPECS:
https://linustechtips.com/topic/904800-help/#findComment-11128739
yeah but even when i downclock the gpu and im able to get in the game there are a bunch of grahical errors (glitches)
6 minutes ago, TechyBen said:
Uninstall the Nvidia driver. Reboot, and download and reinstall the driver. See if that helps first.
did that
https://linustechtips.com/topic/904800-help/#findComment-11128745
9 minutes ago, TechyBen said:
Remover the CPU overclock. Test again.
Which ram slot is the ram plugged into? Is it like this picture in the second slot and the last slot (A2 and B2):
im using the dimmb 2 because i have two sticks and i will try to take off the overclock
https://linustechtips.com/topic/904800-help/#findComment-11128784
