HELP!!!!
3 minutes ago, TechyBen said:
You have to setup exactly as in the picture for the ram sticks. Try 1 stick and reboot, test. Try the other stick and reboot, test.
You wouldn't be getting artefacts if the RAM stick were not installed correctly.  All that would do is stop Dual Channel from working
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
https://linustechtips.com/topic/904800-help/page/2/#findComment-11128956
Artifacting sounds like a fried/overheated gpu to me (just as other users here have suggested)
My PC (Known as Theseus IV):
—CPU: R9 5950X (B2 Stepping)
—Ram: 32GB Vengeance Pro SL RGB
—Graphics: AMD RX 6900XT
—Motherboard: Asus ROG C8DH
—Storage: 990 Pro 2TB
—CPU Cooling: NZXT Z73 RGB 360
—Case: Corsair 5000D Airflow
—PSU: Corsair AX850
https://linustechtips.com/topic/904800-help/page/2/#findComment-11128995
