I'd try re-plugging in the monitor's cable - both to the monitor and the GPU. Perhaps even reseating the GPU. I've seen similar issues that can be fixed by it.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/904527-help-owo/#findComment-11126562
But I never messed with the gpu or anything and it won’t boot up it just stay like that
https://linustechtips.com/topic/904527-help-owo/#findComment-11126671
3 hours ago, Kingdomkey said:
Ok I turned it on and this happened. What is it
This is normally an indication of a dying GPU (at least from my experience). How old is the laptop? Specs? and does it run hot?
Main Rig
CPU: Intel Core i7 920 @ 4.0GHz
Motherboard: ASUS P6T SE
RAM: 10GB OCZ DDR3 (Triple Channel) @ 1600MHz
GPU: NVIDIA GeForce GTX 770 2GB
Case: Antec GX500 Window
Storage: 2 x 500GB Samsung 7200RPM HDD
PSU: Coolmax 1200W ATX 80 PLUS GOLD
Cooling: DEEPCOOL GAMMAXX 300
Teamwolf Mechanical Gaming KeyboardASUS ROG GX850 Laser Mouse
Main Laptop
Alienware 17 (2014)
(Intel Core i7 4710mq @ 2.5GHz - 3.5Ghz (Turbo) | 16GB DDR3 RAM | 4GB AMD m290x Dedicated Graphics - 1TB SSHD)
XP Machine (build in progress...)
CPU: AMD Athlon 64 3000+ @ 1.8GHz
Motherboard: DFI LANPARTY NF4
RAM: 1GB OCZ DDR (Dual Channel) @ 400MHz
GPU: NVIDIA GeForce GT610 2GB Synergy Edition
PSU: BFG 450W
Apple iMac (2009)
CPU: Intel Core2Duo @ 2.66GHz
RAM: 6GB DDR3 @ 1333MHz
GPU: NVIDIA GeForce 9400 256MB
RetroPie Machine (Linux Mint & RetroPie)
CPU: Intel Core2Duo @ 3.0GHz
RAM: 7GB DDR2 @ 800MHz
GPU: AMD Radeon HD 3650
https://linustechtips.com/topic/904527-help-owo/#findComment-11126924
I didn't think those compaq things ever had a dGPU. Usualky issues like this are a bad LCD or bad RAM
https://linustechtips.com/topic/904527-help-owo/#findComment-11128909
Ahh, your right, I stand corrected. it would be integrated so LCD or RAM would make sense.
Main Rig
Main Laptop
Alienware 17 (2014)
PSU: BFG 450W
Apple iMac (2009)
https://linustechtips.com/topic/904527-help-owo/#findComment-11129000
4 hours ago, stateofpsychosis said:
Try plugging it into a monitor
if the issue persists, it's the graphics chip whether it's a discrete GPU or integrated on the CPU..
if it goes away, it's the screen.
well i turned it back on and then the screen turns off
https://linustechtips.com/topic/904527-help-owo/#findComment-11131636
Try plugging it into a DIFFERENT monitor than the screen on it.
Sorry, should have been more specific :P
If you don't have a monitor, plug it into your TV via HDMI.
This will determine which component is the problem.
If it's just the screen, you could technically just plug it into a cheap monitor or your TV and use it that way for now.
https://linustechtips.com/topic/904527-help-owo/#findComment-11131655
