Help! BSOD while playing PUBG.
Solved by henkka_scorpio,
21 minutes ago, Nate03 said:I do not understand anything about the error. Please help. I am worried for I saved money for 5 years to buy this pc.
These are the specs:
Rare BSOD:s arent anything you should be worried about. Especially when playing pubg as it is a bit buggy and ive heard it has some sort of memory leak issues. If it can be replicated then there is a problem. I dont think it is temperature related, but you can check if something is overheating.
