Sound cards
Wingfan
Onboard audio is pretty good now. Any need for a sound card?
Just wondering..
Ryzen 7 5800X3D, Corsair H105, Gigabyte x570 Aorus Elite, Corsair Vengeance 32GB 3600MHz, EVGA RTX 3070Ti FTW3, Samsung 850 Pro / WD SN850 / OCZ Trion 150
ASUS MG279Q, Corsair Carbide 275R
If you feel that it is good then just stick with it.
Don't buy sound cards, buy external DAC/Amps only if you need them. If you are using gaming headsets or cheap headphones then no you don't need one.
Im currently using an AMP/DAC with my DT 990's. No complaints, just wondering if there would be any benefit.
none whatsoever.
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
If you already have an AMP and DAC? no. If you are plugging the AMP into the oboard, then yes. If you are using analog out from the motherboard, and putting it into the DAC, then pushing it to the AMP, or plugging an AMPDAC unit into the analog out of the onboard, then you are doing it wrong.
However, if you have the DAC being used properly as a DAC, then no. A soundcard would be absolutely pointless.
