Anyone have any storage container suggestions for storing extra PC parts laying around? After building and fixing for a few years the parts are starting to take up space and the current cheap tubs they were in aren't sufficient anymore and I'd like to get something that I can use that sorts the parts pretty well, but also has a decent amount of storage. Any recommendations?
https://linustechtips.com/topic/90162-pc-parts-storage-options/
A cardbox refrigerator box? if you owe one.
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/90162-pc-parts-storage-options/#findComment-1218726
The plastic containers, but that might have static build up, so cardboard boxes and paper would be good.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/90162-pc-parts-storage-options/#findComment-1218740
assemble into random computers and fold....
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
https://linustechtips.com/topic/90162-pc-parts-storage-options/#findComment-1218746
I guess that could work. I'd just prefer to use a more rigid storage container. Right now I'm just using plastic tubs you can get at target. Was looking at their sterilite drawer containers but most only had small drawers that could work for storing cables and small parts but not things like motherboards, GPUs and heatsinks. I might just check out storables or something.
https://linustechtips.com/topic/90162-pc-parts-storage-options/#findComment-1218786
Why dont you sell some of it and make money to upgrade your current rig? :)
GILBERNATA
"They will suck your energy from you -- the energy you call money and will put it to evil ends giving you worthless dross in return, Your inner self will protect you from this."
https://linustechtips.com/topic/90162-pc-parts-storage-options/#findComment-1219755
Unfortunately I have a contract-based job that requires me to fly all over the place, leaving me with very little time to tend to my shrine :/. Also, most of the components are things like fans, cables and peripherals.
https://linustechtips.com/topic/90162-pc-parts-storage-options/#findComment-1220630
A big metal tool box like you see mechanics owning in garages with all the shelves and compartments, although idk if that's the best option for random computer parts.
Ive seen very large tackle boxes for fishing as well with some very big compartments on them as we'll as plastic dividers which you can add and take out so everything fits perfectly
https://linustechtips.com/topic/90162-pc-parts-storage-options/#findComment-1220711
I have a bigger, prettier version of this for tools in my shed.
http://www.bunnings.com.au/handy-storage-6-tier-tote-organiser-system_p2760281
If you like the idea but the tub sizes aren't what you want. You can always buy the wire shelving and tubs separately, if you want to hide it / keep some dust out / be able to lock it.
http://www.ausfile.com.au/images/cupboard.png instead + tubs
I'm considering doing this for my computer stuff. My current system of 4 large boxes is pretty annoying.
https://linustechtips.com/topic/90162-pc-parts-storage-options/#findComment-1221016
That 6 tier organizer definitely piqued my interest and is definitely something that could work.
https://linustechtips.com/topic/90162-pc-parts-storage-options/#findComment-1221907
