check out gamers nexus last video none of those numbers are real. if you really want to know what voltage is going through you need to take a multimeter to measure it yoruself
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/901548-wrong-cpu-voltage/#findComment-11096542
But should i worry that my cpu gets to much voltage?
https://linustechtips.com/topic/901548-wrong-cpu-voltage/#findComment-11096593
Software is never 100% accurate. If it's stable, I wouldn't worry too much.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/901548-wrong-cpu-voltage/#findComment-11098083
What board is this? Going off the video trust the voltage you type in more than anything and if it's gigabyte don't trust anything at all. Granted that was on ryzen but i think they'd keep the same behaviours.
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/901548-wrong-cpu-voltage/#findComment-11098877
I have an msi z170m mortar motherboard.
https://linustechtips.com/topic/901548-wrong-cpu-voltage/#findComment-11100219
