Is there a product that holds your Ethernet cable in place?
1 minute ago, ntl0se said:
I notice that part of it is missing from my connector part it must bean broken for a while now 2-3 months and I just got sick of always plugging in can i buy the connector part at itself and rewire it and do I need any special tools for the wiring or do you have to buy the whole cable leading up to the router and the connector IDK I'm not too familiar with networking.
You can buy connectors on their own and rewire it, but you will need an RJ45 crimping tool. If it's just a one off time, you're likely going to spend a similar amount of money buying a new cable as you would buying the tool and connectors (you generally can't buy just one connector on its own).
You'd need to check what standard the other end of the cable uses and match it. Most cables will use the TIA-568B standard, but they may use TIA-568A, so you'd need to check the order of the cables.
