Motherboard keeps beeping at me and the beeps aren't relating to anything on the internet. I tried removing ram, didn't change. I started doing stress tests to single thing out as the mobo would only beep during gaming. AIDA64 resulted with nothing different. Furmark made it beep when TDP went over 93%. So I'm wondering if its a PSU issue? From what I've read, PSU's just die, there is no in between. Really just trying to figure out which part I need to RMA.
PCPartPicker part list: https://pcpartpicker.com/list/DdVHxG
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor
CPU Cooler: Corsair - H115i 104.7 CFM Liquid CPU Cooler
Motherboard: MSI - Z370 GAMING PRO CARBON ATX LGA1151 Motherboard
Memory: G.Skill - Ripjaws V Series 32GB (2 x 16GB) DDR4-2133 Memory
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Crucial - MX500 500GB 2.5" Solid State Drive
Storage: Seagate - BarraCuda 4TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI - GeForce GTX 1070 8GB Video Card
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Operating System: Microsoft - Windows 10 Pro OEM 64-bit
7800X3D | Noctua NH-D15 Asus B650 ProArt-Creator 32GB 6000mhz GSkill S5 Asus TUF RTX 4090 | Corsair HX1000i | Sandisk 1TB NVME boot, Sabrent 2TB NVME, Crucial MX500 1TB, Crucial MX500 2TB | Lian-Li O11 Air Mini |
https://linustechtips.com/topic/900997-weird-psu-issues/
What beeps is it making?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11091124
5 minutes ago, Army165 said:
-snip-
If it's a beep coming from the PC speaker, it's probably dumb things like sticky keys kicking in (though sticky keys will often open a pop up). Weird key combinations can also cause your board to beep for like invalid inputs.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11091140
One long beep. Over and over.
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11091141
You sure it's not one long two short, as that's the GPU error beep code?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11091152
No dude, one long beep. I don't have other cables or I would try swapping them out. I switched them around and made sure they were secure on the back end of the PSU. When the beeping happens, nothing else happens. No blue screens, no stuttering, nothing. Just noise from the mobo. Honestly never had an issue like this and the info online is lackluster.
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11091176
There's literally no info anywhere on this. Try contacting MSI.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11091182
I know. Which is frustrating. I run Furmark (1440p, 2x msaa and power limit at 126, no OC), it will get above 93% TDP and start screaming at me.
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11091186
As Jonny said, that's just wrong, totally.
There are some kind of intermittand failures of a PSU, especially things like broken SOlder Joints and other stuff...
It would have been great if that was the case but it is not.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11092877
@jonnyGURU, I used your review to make the decision on this PSU. Thank you for the work you do, its much appreciated.
As noted above, I was able to replicate the issue during Furmark. It would run Furmark just fine but if I did something in the background(and the TDP was over 93%), like open a google page, it would trip the beep. The weird part is that nothing actually happens during the beeping. No drop in FPS, no stutter, no special screens.
I am dreading the RMA, I hope its relatively quick.
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11093395
You're sure it's not an over temperature warning from the motherboard?
In most BIOS's these days, you can set an audible alarm and what temperature you want that alarm to go off at.  Go into your BIOS and either raise that threshold or turn off the alarm and see what happens (assuming your board has that feature).
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11093554
I shall try this and report back.
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11093565
I found no such values in searching around the BIOS and the user guide.
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11093630
I bought a second PSU, the Platinum version. I will report back after installing that Friday. If its still an issue, its clearly a mobo issue.
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11093643
Figured it out. Feel really stupid now. UPS is beeping as I'm drawing too much power from it. When running Furmark, the UPS makes the beeping noise and the power light goes to amber. Thanks for the responses.
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11093824
Yes, its an LG lg 34UM69G-B.
https://linustechtips.com/topic/900997-weird-psu-issues/#findComment-11093849
