NEED HELP FINDING A PSU
so i bought the wrong power supply because the one i bought only has one 8 pin cable for the  cpu but i need two one to power my cpu and my graphics card i have the gtx 1060 6gb msi gaming x version if you want to see what i bought its all in a list at pc part picker https://pcpartpicker.com/list/48Hbvn
https://linustechtips.com/topic/900834-need-help-finding-a-psu/
https://pcpartpicker.com/product/FQ648d/corsair-power-supply-cp9020101na
This PSU more than fits your needs.
450 watts is plenty, it's semi-modular, and it's a quality/good performing unit.
AX1600i owner. https://docs.google.com/spreadsheets/d/1_GMev0EwK37J3zZL98zIqF-OSBuHlFEHmrc_SPuYsjs/edit?usp=sharing My WIP Power Supply Guide.
https://linustechtips.com/topic/900834-need-help-finding-a-psu/#findComment-11089231
do you know a 100% that it has two 8pin connectors because i dont want to make the same mistake
https://linustechtips.com/topic/900834-need-help-finding-a-psu/#findComment-11089241
While that PSU is definitely not recommend for your PC, it does contain the right connector for it. One 8 Pin EPS (CPU) connector and two 6+2 (or 8) pin PCIE connectors.
The VS series is meant for office builds and not full gaming builds, this is more what Corsair's CX series is meant for.
https://linustechtips.com/topic/900834-need-help-finding-a-psu/#findComment-11089242
It has an 8 pin for the CPU and two 6+2 pins for PCI-E
http://www.corsair.com/en-us/cx-series-cx450m-450-watt-80-plus-bronze-certified-modular-atx-psu-na
There's all the cables it comes with.
the psu calculator said i should be fine
The VS is simply a garbage PSU. Has nothing to do with wattage.
https://linustechtips.com/topic/900834-need-help-finding-a-psu/#findComment-11089253
The wattage is fine, the series, as I said, is not meant for these type of builds.
Wattage does not equal quality. I understand 20 USD seems like a steal, but there is a reason it is so much cheaper than other PSU's.
This would be a better alternative IMO: https://pcpartpicker.com/product/3hkwrH/corsair-power-supply-cp9020102na
Way better quality than the VS series, contains all the necessary connectors and is even semi modular.
https://linustechtips.com/topic/900834-need-help-finding-a-psu/#findComment-11089287
A Corsair CX550M would have the connections you need.
Keep in mind, there's a difference between the "8-pin" you use for your CPU (4+4 pin connection) vs the "8-pin" (6+2 pin) you use for your GPU. They won't fit the same way so there should be no risk of plugging them in the wrong way.
https://linustechtips.com/topic/900834-need-help-finding-a-psu/#findComment-11089352
Actually, the one in his PC Parts Picker is the new VS Full Range made by HEC.  It's quite good for the money.
It's the one with the orange label that's the 230VAC only from CWT.  That one had some issues.
https://linustechtips.com/topic/900834-need-help-finding-a-psu/#findComment-11090327
Hm, is there a review of it that I can see? I'd like to look at its exact specs and what it looks like on the inside.
https://linustechtips.com/topic/900834-need-help-finding-a-psu/#findComment-11091189
4 hours ago, Rexper said:
Might want to take the "page=2" off your URL since it goes to a page that doesn't have the internal photos you're referencing.
Also, since that forum thread was going on over a year ago, the ErP 2013 requirement has been added to the VS Series and is now sold in the EU.  You can tell the difference from the wattages.  The ones without ErP 2013 efficiency requirements are 400, 500 and 600W.  The ones sold in the EU with ErP 2013 are 450, 550 and 650W.  But all of them have the gray label.
https://linustechtips.com/topic/900834-need-help-finding-a-psu/#findComment-11092250
