Need help with buying a graphics card!
Solved by MadOverclocker,
5 minutes ago, MrBoggas said:Well I'm not really sure what diffrence the "Ti" makes and getting the Ti would be about $100 more than the one without, as the one I'm planning to get is on sale. Also, do you believe the 2GB VRAM previded would be enough for todays games or do you believe it would perform bad?
Ti 100$ more? Forget the Ti. The Ti just has like 7%-15% faster and with 4GB GDDR5. 2GB will do just enough for games. Most games will run good on 2GB my card right now has 1GB GDDR5 and some games struggle but end up running perfect with a bit of tweaking.
