Vinyl questions
Go to solution Solved by W-L,
1 minute ago, aries757 said:
so i would need a vinyl plotter?
Yes you would require a vinyl plotter for complex designs, anything simple can be done by hand.
so in a c U s t om build i am doing i am having a fun time with acrylic and vinyl, but..
i saw in a video where someone maybe used vinyl (or paper idk) and had a image/print on it and used tape to pull it off then put it on acrylic
how would i go about doing this? wasn't very specific
MF UH BEANS
https://linustechtips.com/topic/898927-vinyl-questions/
You either buy a $5000 vinyl cutter or you pay someone to make it for you.
https://linustechtips.com/topic/898927-vinyl-questions/#findComment-11070529
What he's using is transfer tape, it's very useful for complex vinyl designs that allow you to take a cut design and transfer over toy your part instead of trying to line up and stick each and every portion. The design is not printed but cut on a vinyl plotter before remove the excess leaving you with your design that then requires the transfer tape.
https://linustechtips.com/topic/898927-vinyl-questions/#findComment-11070532
MF UH BEANS
https://linustechtips.com/topic/898927-vinyl-questions/#findComment-11070540
2 hours ago, MeDownYou said:
What do you need? If ya want something like in the video let me know can probably sort ya out.
odd requests but, tyler the creators face, the odd future donut sign (OF)
alot of bees. (10 or so) and flowers..
the rest i can sort out. if you are willing to help out.
MF UH BEANS
https://linustechtips.com/topic/898927-vinyl-questions/#findComment-11077321
