So I'm thinking about getting a Ryzen 1500x to replace my X4 860K because I literally can't run any ubisoft games without my cpu being at 70-100% and my fps being horrible.
But I need to know if a Ryzen1500x pairs well with a GTX 1050ti Superclocked. (also I only have 8gb of ddr3. should I upgrade that to 16gbs?)
https://linustechtips.com/topic/898497-help/
yes u shoould upgrade 16gb ram and get new pair cpu Amd Ryzen 5 2400G which include iGPU.
----------------PC RIG-----------------
Motherboard-ASUS PRIME A320M-K
CPU-AMD RYZEN 5 1400
GPU-ZOTAC GTX 1050Ti 4GB OC Edition
RAM-Kingston 8GB DDR4 2133MHZ
HDD-WD BLUE 1TB HDD
SSD- Kingston A400 SSD 240GB
PSU-CORSAIR VS550Watt PSU
Monitor-Dell S2218H Full HD
https://linustechtips.com/topic/898497-help/#findComment-11066094
get a 2400g rather than 1500x.
1050ti can run with any cpu.
https://linustechtips.com/topic/898497-help/#findComment-11066113
HDD-WD BLUE 1TB HDD
https://linustechtips.com/topic/898497-help/#findComment-11066123
ah. What about the 1600?
well its better ryzen 5 1600x as 6 core fastest procosser.. and yes its also good ryzen 5 1600.
HDD-WD BLUE 1TB HDD
https://linustechtips.com/topic/898497-help/#findComment-11066142
If OP is okay overclocking then ignore the 1600x. Get the 1600 and OC it. Mine got to 3.9 GHz with little voltage bumb so even if they only went to the 3.6 of the 1600x it probably wouldn't need any extra volts
|| CPU: AMD Ryzen 5 1600 (@3.9GHz) || Motherboard: ASUS Prime B350 Plus || Cooler: Arctic Freezer 33 eSports Edition || GPU: EVGA GTX 1070 SC || Memory: 16GB G.Skill Trident Z RGB C16 (@2933MHz) || SSD: SanDisk 128GB || HDD: WD Blue 2TB, Toshiba 2TB, Transcend 1TB || PSU: Corsair RM550x || Case: Fractal Design Focus G || Monitor: 2x AOC 23” I2369VM IPS Full HD, Samsung 32" LED TV Monitor || Mouse: Logitech G703 Wireless || Keyboard: Cooler Master MK750 RGB (Cherry MX Brown) || Speakers: Dell Stereo Speakers || Headphones: Sennheiser HD 4.40 BT / Samsung Galaxy Buds ||
https://linustechtips.com/topic/898497-help/#findComment-11066177
I have no idea how to oc xD
https://linustechtips.com/topic/898497-help/#findComment-11066255
search "how to oc ryzen 1600", you'll find many guides to do it.
https://linustechtips.com/topic/898497-help/#findComment-11066266
If paired with 1050ti, absolutely.
Its the best bang for the buck in current Ryzen lineup.
https://linustechtips.com/topic/898497-help/#findComment-11066298
Yes, 1600 would be just fine.
1600x would need another $30 to get a decent heatsink, as it doesn't come with one.
https://linustechtips.com/topic/898497-help/#findComment-11066310
alrighty. Will this actually be able to run r6 at 60 fps?
I built my pc in like..2016 but I never did anything on it and never played it so I'm kinda new to all of this.
https://linustechtips.com/topic/898497-help/#findComment-11066318
You cannot use DDR3 with Ryzen so you'll be looking at moving to DDR4
https://linustechtips.com/topic/898497-help/#findComment-11066411
5 hours ago, Darkdestroyer445 said:
Yeah, I found that out about 15 minutes ago. lol
well its good pair ryzen 5 1600 and gtx 1050ti.well for my choice why not get GTX 1060?because u can play more years for GTX 1060.
HDD-WD BLUE 1TB HDD
https://linustechtips.com/topic/898497-help/#findComment-11067628
7 hours ago, Darkdestroyer445 said:
Also, do you happen to know if the Wraith Spire cooler that it comes with is any good?
its super!
35 idle, 60 load.
https://linustechtips.com/topic/898497-help/#findComment-11067664
Simple answer - Cost. 1050ti isn't crazy inflated from mining. 1060 is
https://linustechtips.com/topic/898497-help/#findComment-11069829
