Hey guys, so I have a ASUS Strix 980ti.
Now, the primary fan is failing, very badly actually. The bearings are just about shot (I think given the sound it's making) and it can't really turn anymore.
Obviously this makes it have difficulties running games bc I have it limited to 85C to avoid possible damage, and it hits that idling in FF14.
So, I bought this card second hand (lightly used, about a little over a year ago, before crypto mining was huge, it's not a damaged card) so RMA is out of the question.
My question is, is the cooler repairable? I doubt ASUS has the fans available to just buy outright, and even if someone did I bet they're kind of a pain in the ass to replace.
I'm guessing that's pretty much my only option because iirc the Strix cards are custom PCB, so most 3rd party coolers are out of the question.
The only other option I could think of would be doing a Custom WC loop using an EKWB strix block. While this would obviously be the most expensive option it might also be the most viable (unfortunately) as I'm not sure of the availability of the main fans (I found some on aliexpress but I'm not too sure of the sizes on the cooler as they seem to be different). Would help keep temps down though, if I went that route I'd also pick up a WB for my cpu so that would be cool (haha).
However I'd much rather take either of those options over trying to buy a new GPU given the current situation with prices etc, especially in Canada.
Thanks for any input you can provide :^)
https://linustechtips.com/topic/898053-graphics-card-cooler-fixreplacement/
Just now, For Science! said:
You could attach normal case fans
I've done my time in ghetto pc building already.
It wasn't my PC of course. But I've done it.
It seems like a great temp fix, but I'd like something more concrete.
8 minutes ago, TheGreatWizardCalder said:
Pretty sure the warranty covers fan replacements
but just zip tie a 120mm fan to the cooler
There is no better fix outside of buying an aftermarket GPU heatsink, and something like that isn't worth it over strapping a fan to it
See op. GPU is second hand, I don't get warranty.
I do however have the contact of the guy I got it from and see if he has any warranty info from the local store he got it from.
Just now, Generallee said:
Well watercooling seems the way to go for you, still would be cheaper than buying a whole new gpu considering today's  general bamboozling on gpu pricing
Yes, tbh with current GPU pricing that's what I was thinking too.
Also not worth it unless you already have a custom loop and they make a water block for it, or you know the custom PCB(if it has one) won't interfere with the water cooling kits.
It also takes way more work as you have to actively cool the VRMs as well, just get a low profile fan on it, or maybe find a dead one on ebay you can steal the shroud from.
Dunno man, my opinion is the investment in a waterblock + all the extra watercooling stuff (fittings, pump, radiators etc) is almost creeping into territory of a new card. Seeing as ampere may be around the corner, I think strapping a fan on is a perfectly concrete solution until new architecture arrives.
If I spent $400 on a loop only to cool a previous gen graphics card and then get a new graphics card arrive, I would be pretty salty.
no need for watercooling. just buy a replacement fan with the same fan header. if not, you can cut the header from old fans and connect the correct wire to the new fans. problem solved.
https://www.ekwb.com/shop/ek-fc980-gtx-ti-strix-nickel
Now whether or not I could find one is questionable, but they do, or rather did, make blocks for the strix PCB. I knew this before hand though.
They make full cover blocks that cover VRMs.
While this is an option, given what I play I'm not really in the market for a new GPU. Going any higher would probably end up having throttling issues with my CPU.
If I went the loop option it's not like I could just buy a WB for the new card though. Although that's considerably more expensive.
The main thing to consider though is I wouldn't be upgrading for a while. I pretty much play FFXIV and other games that are easily in the realm of my 980ti running at 3440*1440. I'm not a baller trying to run new technically impressive games (not that there have been any recently) on my fancy high res monitor. A WB would possibly allow for better OCs allowing me to last it longer though. While this is currently what I'm leaning towards, I'm not one to make split decisions. That and finding the WB could be a PITA.
Definitely doable but I'm an idiot and not sure if I trust myself with that.
And I need to find the correct fan model. Probably not that big of an issue either.
1 minute ago, TheGreatWizardCalder said:
Dude. Just zip tie a fan to it and end the madness! It's a $15 or less fix, or if your case has side intake put a fan there and set it to the max speed
or just undervolt/underclock your GPU so it'll run semi-passively
Possible temporary fix. I don't like to visit the ghetto realm though. While it works, it's just personal pet peeve. If the fan dies right out I'll do it until I work out a longer term solution. I do believe in the LTT video about this though the card, while performing much better than no fan, still performed at a fairly significant higher temp. Not sure if I want that as a long term solution for a variety of reasons.
I idle at 50 C with the cooler fully functional. That's more of a last ditch thing :P
All you need a static pressure optimized fan, like this Fractal HP-14, which can fit onto 120mm fan slots, it'll force the air through the heatsink and should work well enough
https://www.newegg.com/Product/Product.aspx?Item=N82E16835352024
I have plenty of spare fans sitting around, including a handful of Noctua ones.
IDK how that goes as far as a long term solution though.
Its really not that difficult, pop out the broken fans and determine the specs.
usually i they write the volts/amps on the bottom.
find a matching specs and you're good to go.
no need to replace all the heatsinks, leave the heatsink untouch.
Get a very good quality aftermarket fans, nice good build and smooth bearings, it will be better than the old one.
You can also amp up to get faster air speed. Just don't mess with the voltage.
Yeah I'll definitely give it a go.
IDK if aliexpress takes paypal tho.
Eh I'll figure something out I'm sure.
yes they accept paypal
watercooling is an option
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
could slap an aio on it with this
https://www.newegg.com/Product/Product.aspx?Item=N82E16835146036
just make sure you look up compatibility for your card and which aio's work with the g10, and also get a stronger 92mm fan than what comes with the g10. it's a hassle, but i got my card down from around 30c idle and 75c load to 20c idle and 40c load in a 19-20c environment.
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
