Hi guys, First post and I already need help  :P
I'm planning to build a custom loop , I read the sticky but it got me even more confused
So far my build is
HAF XB Case
I7 3770k
MSI GD46 gaming Mobo
2x AMD r9 290x
Corsair 850 PSU
and the rest is irrelevent
I want to build a custom loop that can handle all that
I need to know if this kit would do the job? http://products.ncix.com/detail/xspc-raystorm-d5-ex360-water-cooling-kit-am2-am2-am3-am3-lga2011-1366-1156-1155-775-bf-79208-1198.htm
Will one rad do the job? if not how many would i need for optimum cooling?
https://linustechtips.com/topic/89757-need-help-please/
For a 3770K and 2 R9 290Xes? It will work, but you won't be satisfied with the temperatures. Try to put more rads in the case. Maybe an extra 240MM. If not, get a new case.
https://linustechtips.com/topic/89757-need-help-please/#findComment-1213436
Triple 120 will work but meh...
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/89757-need-help-please/#findComment-1213465
  • 3 months later...
Hey guys just a small follow up. Thanks to all your help i got my water cooling rig finished
The products I used are
XSPC Raystorm 750 AX240 Water Cooling Kit
XSPC Razor R9 290X X2
Black Ice GTS Stealth 120 Gen Two Stealth Single 120mm Fan Radiator
Feser One Fluid Pure Blue NON-CONDUCTIVE
I didn't change my case since i wanted to invest in the water cooling rig. this may not be enough for some of you guys but it made wonders for me!!
The CPU on idle is at 31 degrees and no more than 45-50 under load
My two r9 290x are 31 degrees on idle and 42 degrees on load. It was well worth my investment and I'm happy I didn't mess things up . No leaks or bubbles . I'm proud of myself
Again thank you all for your help and advice!
Here are some pictures
https://linustechtips.com/topic/89757-need-help-please/#findComment-1766809
congratulations!
keep a close eye on the 750 pump. it generally is not a recommended pump for multi-block
use. too much restriction and the pump will die a slow death or just quit. great temperatures,
what voltages on the overclocks?
https://linustechtips.com/topic/89757-need-help-please/#findComment-1768804
congratulations!
No overclocks. did this for noise and temperature.
how will i know if the pump dies?
https://linustechtips.com/topic/89757-need-help-please/#findComment-1768961
temps creeping higher and higher. watch your reservoir "swirling pattern" for low/no
activity. these pumps were mainly for single block use. a couple LTT members went
the 750 for "budget" and got dead pump syndrome in under 2weeks.
https://linustechtips.com/topic/89757-need-help-please/#findComment-1768981
I'll keep an eye on that for sure. So far so good *knock on wood*
Worse case i can replace the pump with the D5. Is the D5 any good?
https://linustechtips.com/topic/89757-need-help-please/#findComment-1770914
