Python Help
By
Hugs12343
in Programming
in Programming
Solved by Guest,
To expand on the options presented by @straight_stewie
# f-string, which is only availible in 3.6 or higher print(f"Your fuel cost is ${final_cost}") # alternativly you could change it to a string mid line print("Your fuel cost is $" + str(final_cost))
kerriya ·
Posted in Cases and Mods3 -
octester ·
Posted in Troubleshooting5 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
bill well ·
Posted in Peripherals1 -
4
2
Ha-Satan ·
Posted in Networking3 -
1
play_circle_filled
Latest From ShortCircuit:
