A friend of mine needs Solid Edge for school and is interested in getting a new PC. What hardware preferences does the program have? Is there anything else we have to keep in mind when building a PC for this task?
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/895489-solid-edge-pc-question/
While I haven't delved into solid edge very much other than the rare of times I've had to use it, like most CAD programs it should be heavily CPU based similar with Solidworks and the like with little real need for high end GPU power unless in very specific applications.
https://linustechtips.com/topic/895489-solid-edge-pc-question/#findComment-11034156
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Geforce-GTX1080Ti-or-Quadro-P4000-same-price-which-difference/td-p/446979
https://community.amd.com/community/amd-business/blog/2015/07/08/amd-firepro-and-siemens-plm-software-8211-help-you-realize-innovation
It seems that a workstation card is good to have but a gaming card wont work well. Clearly a software lock seen in many CAD software since it uses OpenGL itself.
https://www.plm.automation.siemens.com/en/products/solid-edge/design/system_requirements.shtml
Also needs Windows Enterprise or Pro (64bit), as well as new MS Office versions
Desktop benching:
https://linustechtips.com/topic/895489-solid-edge-pc-question/#findComment-11034223
I thought it is more CPU intensive?
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/895489-solid-edge-pc-question/#findComment-11034230
Dont get me wrong, you can use it without a graphics card as long as there's an integrated one. I assume not having a graphics card will slow it down just like other CAD programs, but I'm not sure on how much it affects.
The forum post did say that a K4200 (same core as GTX 670) is good enough, which has P1000 (GTX 1050 with 4GB VRAM) performance and is good news to the wallet.
Desktop benching:
https://linustechtips.com/topic/895489-solid-edge-pc-question/#findComment-11034258
