Searching for 3 arm monitor mount
Solved by Unimaginative Name,
2 minutes ago, Drazlak said:I am looking for a 3 arm monitor mount that can have a 40 inch tv in the center and 2 27 inch monitors in Portrait mode on the sides of the tv.
If there isn't anything ill just make my self a custom one but just wanted to see if there is already a product
TVs generally use a different mounting standard from monitors. You would have to find a mount for 3 TV's and then adapt them to VESA mounts. I don't even think that triple TV mounts exist. Probably easiest to custom make one with a TV mount in the middle and vesa arms coming off the sides. You can make something with three of these.
https://vivo-us.com/collections/monitor-mounts/products/mount-vw06q - same link as above
