1 minute ago, Andrew-Theodor said:
Hello! My name is Theodor and I'm currently looking forward to build an 800$ Gaming Pc
One of my close friends offers me a gtx 980 ti for 395$ and I really want to include it into my config !
Can u help me to complete the config with the buget of 800$ pls ? :)
194167551_1_94x72_placa-video-gigabyte-gtx-980ti-windforce-cutie-accesorii-garantie-emag-iasi.jpg
what mobo,cpu,psu,storage,case are u getiing?
https://linustechtips.com/topic/895082-800-gaming-pc-help-me/#findComment-11030611
7 minutes ago, ONOTech said:
This is the best I could do for $800, but I cut some corners.
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor  ($149.89 @ OutletPC)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3000 Memory  ($93.99 @ Newegg)
Case: DIYPC - DIY-F2-W MicroATX Mini Tower Case  ($29.98 @ Newegg)
Power Supply: SeaSonic - S12II 520W 80+ Bronze Certified ATX Power Supply  ($42.99 @ SuperBiiz)
Other: 980 Ti ($395.00)
Other: 1 TB from eBay NEW ($35.00)
Total: $806.84
Generated by PCPartPicker 2018-02-10 11:22 EST-0500
For another $100, you can get this: more cores and threads, better power supply, better motherboard, and a better case.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($189.99 @ Newegg)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($74.39 @ OutletPC)
Storage: Toshiba - 1TB 3.5" 7200RPM Internal Hard Drive  ($42.19 @ OutletPC)
Case: Corsair - 100R ATX Mid Tower Case  ($44.99 @ Newegg)
Power Supply: SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($57.99 @ Newegg)
Total: $898.54
Generated by PCPartPicker 2018-02-10 11:24 EST-0500
That memory is not on the motherboard memory QVL list
Audio go Brrrrrr
https://linustechtips.com/topic/895082-800-gaming-pc-help-me/#findComment-11030665
Just now, ONOTech said:
I'm not the best with power supplies, but JG gave it a 9.4/10. Granted it was in 2013, so standards change all the time. It looks like a solid choice - just not as modern as other options
If you have an alternative that's better and will keep the budget around $900, you're more than welcome to recommend.
The TX550M is available for $50 after a $10 rebate.
I would change the RAM to the 1x 8GB stick, for upgradability, and maybe the case, but it's a good build
https://linustechtips.com/topic/895082-800-gaming-pc-help-me/#findComment-11030668
I've used the same module in my B350 Prime-Plus and it ran at its rated speed (well, 2933).
ok, then I suggest he get's the same board.  It's a uefi thing for compatibility not a cpu thing.  At least that's my understanding.  My Trident Z wouldn't run at anything but 2133 on my z270 until Asus updated the BIOS
Audio go Brrrrrr
https://linustechtips.com/topic/895082-800-gaming-pc-help-me/#findComment-11030698
15 minutes ago, Psittac said:
I have to reiterate, you need memory from the qvl list from the motherboard manufacturer, this is going to be your biggest hurdle
After the Agesa 1006 update, Hynix kits can mostly run at 3000MHz
https://linustechtips.com/topic/895082-800-gaming-pc-help-me/#findComment-11030735
