dual monitor with 1060
Rohat
Hey i had a question is it possible to use a gtx 1060 for 2 monitors? it has 1x hdmi port 2x dp. Both monitors are 75hz and one is 1920x1080 and the other 2560x1080.
Yes it is.
✨PC Specs✨
AMD Ryzen 7 3800X | MSI MPG B550 Gaming Plus | 16GB Team T-Force 3400MHz | Zotac GTX 1080 AMP EXTREME
BeQuiet Dark Rock Pro 4 Samsung 850 EVO 250GB | NZXT 750W | Phanteks Eclipse P400A
Extras: ASUS Zephyrus G14 (2021) | OnePlus 7 Pro | Fully restored Robosapien V2, Omnibot 2000, Omnibot 5402
Yup
Try using the PSU Tier List!
How to reset the bios/clear the cmos
My current rig:
CPU: Ryzen 7 3700x
Ram: 1x16gb DDR4, 2x8gb DDR4
Storage: 1tb nvme ssd
GPU: gtx 3080
Monitor: 23.8" Dell S2417DG 144hz g-sync 1440p + 27" Acer S271HL 60 Hz 1080p
Keyboard: ducky one I | I SF
Mouse: gpro wireless | glorious model o2 wireless
Sound : beyerdynamic 1990 pro | Monoprice liquid spark (amp) + topping d10 (dac)
It’s possible to use dual monitors on computers from the 90s. Any modern computer with the outputs can use multiple displays. If it has 5 outputs, you can use 5 displays.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
Yes. Gaming performance when using both as game screen will suffer, but other than that it will work perfectly.
Desktop benching:
this is not true, at least not in a practical use case because while you can connect 5 monitors if you have 5 outputs you will not be able to display different content on all of them, some of them will just be mirrored.
for example if you have HDMI and DVI ports on the GPU you will only be able to drive two monitors even if you have one HDMI and two DVI.
This is why most people have to use at least tone display port once they go above two monitors.
The same applies to graphics cards marketed as "flex display" or an other marketing term, for example my 980Ti has 2 DVI, 3 DP and 1 HDMI but it can only drive a maximum of 4 displays.
