Hi,
I currently have a 1tb HDD with Windows 8.1 on it, and I have just bought an SSD with the idea of putting Windows 10 on it. I unplugged my HDD and plugged my SSD in and installed windows, and now I have plugged both of them in. Everything is working perfectly, but how would I get rid of Windows 8.1 on my HDD? Should I have done things differently?
Thanks in advance.
https://linustechtips.com/topic/893489-ssd-and-hdd-help/
Boot to your SSD, and hit Windows+R on the keyboard. Type in diskmgmt.msc and hit Enter.
From there, you can format your hard drive and delete all the data from it, assuming you don't need it. If you do need it, you can go to the file explorer and copy them from your hard drive to your SSD.
https://linustechtips.com/topic/893489-ssd-and-hdd-help/#findComment-11013688
10 minutes ago, loubot1 said:
Hi,
Thanks in advance.
if you plan on formatting the drive completely check the games your going to lose. some games like max payne 3 and wolfenstein dont auto save through steam. you will have tp back up those saves. otherwise your best bet is to format and re-install all your games.
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
https://linustechtips.com/topic/893489-ssd-and-hdd-help/#findComment-11013724
