i7 8700's clock speed.
Solved by Princess Luna,
1 minute ago, mrchow19910319 said:Will I notice any sort of differences in game as well as non-gaming tasks??
Well obviously since it boosts the frequency of the cores, getting the actual real example of the i7 8700k, it's normal behavior is identical to the i7 8700, its single core turbo boost is of 4.7ghz however if you use all cores at once it'll fall down to 4.3ghz, now if you enable MCE then you'll force the all core turbo boost to 4.7ghz the same as if single core boosting.
This means instead of having 6 cores working at 4.3ghz now you have 6 cores working at 4.7ghz, so pretty much any application benefits from it.
Again I can not stress enough that MCE only works for unlocked processors and that statement on OP's picture is wrong.
