Posted January 31, 2018 So my time for doing some maintenance on my Define C build is up coming. I plan to do some upgrades aesthetically and currently really on the fence about whether to continue using blue coolant, or to switch to clear coolant. I thought If you guys would cast some votes, I can decide whether I like the votes, or whether I'm salty about it (and so either way, I will find out what I truly want :P). I will be re-doing quite a number of bends, and transplanting the loop to a different case :). Recent builds: Meshify C (Zero Tolerance!) & View 37 (Breathable Quad 2080Ti + 2990WX) Best documented PC coolants Older Builds Spoiler Full-custom loop builds: Meshify C (Full custom loop SLI), Ncase M1(8700K + 1080Ti Full custom loop) Obsidian 900D (1950X + Quad 1080Ti) & Fractal Define C (1080 in SLI) Air-cooled builds Air 740D (1920X + Quad 980Ti) & Fractal Define C (Version Air!) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31, 2018 I personally think you should go for primochill vue that fluid is so cool, I love it in my rig. main system build --> i7-7700K (at 5.0 ghz), MSI Z270 SLI Motherboard, corsair vengeance lpx 8gb ddr4 2666mhz, costume liquid cooling loop with 360 mm radiator on CPU, GTX 1080 gigabyte windforce OC, 1TB WD drive, 128 gb samsung nvme m.2, EVGA 850 watt semi modular power supply, CM storm stryker case (ya not ideal for costume loop), VIOTEK GN34C 34 inch curved monitor <---- Spoiler " We are told to remember the idea, not the man, because a man can fail. He can be caught, he can be killed and forgotten, but 400 years later, an idea can still change the world." Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 31, 2018 I think clear would be a nice classy look with all the black, grey and white going on in the rest of the build. The blue doesnt look bad, but is too "gamery" for me. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
